文献标题:Triple targeting of STING, TGF-β, and PD-L1 boosts CXCL16–CXCR6 signaling for potent antitumor response
发表期刊:Nat Commun. (IF=15.7)
DOI:https://doi.org/10.1038/s41467-026-69456-3
使用 Absin 产品:脱氧核糖核酸酶Ⅰ(牛胰)(货号:abs47047435)
本研究围绕核酸代谢与细胞功能调控展开,采用分子实验 + 细胞模型双维度验证策略,完整逻辑链如下:
二、核心研究成果:abs47047435 支撑的关键发现(对应原文图表)
1. 高效清除 DNA 污染,保障 RNA 样本纯度(原文Figure 1)
A Tumor growth curves of EMT-6-bearing mice treated with control IgG (CTL) or YM101. Tumors were collected on day 19 (n = 8 for CTL; n = 9 for YM101). B Tumor growth inhibition (TGI) of individual EMT-6 tumors; TGI < 50% was defined as nonresponder, and TGI ≥ 50% as responder. C GSEA of the GO term “innate immune response” comparing YM101 responders versus nonresponders in EMT-6 tumors. D Top enriched immune/cytokine GO terms ranked by normalized enrichment score (NES); all terms shown have FDR < 0.05. E Tumor growth curves of CT26-bearing mice treated with CTL or YM101. Tumors were collected on day 18 (n = 6 for CTL; n = 15 for YM101). F TGI of individual CT26 tumors. G, H GSEA of the GO terms “innate immune response” and “response to IFN-β” comparing YM101 responders versus nonresponders in CT26 tumors. I Overlap of upregulated DEGs (UpDEGs) in YM101-responsive EMT-6 and CT26 tumors; representative genes are listed. J Functional enrichment analysis of overlapping upregulated DEGs. K Intratumoral cytokine profile in EMT-6 tumors from an independent cohort after YM101 treatment (n = 6 for responders; n = 5 for nonresponders). L, O Representative tumor images from EMT-6 and CT26 models treated as indicated. M, P Tumor growth curves of EMT-6 and CT26 models (n = 8 mice per group). N, Q Kaplan–Meier survival curves for EMT-6 and CT26 models (n = 8 mice per group). A, E Data are mean ± SD. The P values shown were calculated using two-tailed unpaired t-tests. M, P Data are mean ± SD. Statistical comparisons were performed using one-way ANOVA followed by Holm–Šídák’s multiple comparisons test. N, Q P values were determined by the log-rank test. Statistical significance: *P < 0.05; **P < 0.01; ***P < 0.001; ****P < 0.0001. Source data and exact P values are provided in the Source data file.
2. 精准支撑蛋白 - DNA 互作分析(原文Figure 3)
For scRNA-seq analyses, n = 3 independent pooled samples per group (each sample pooled from tumors of two biologically independent mice; 6 mice per group in total). A Scatter plots comparing the outgoing (x-axis) and incoming (y-axis) interaction strengths of T cells in combo vs. CTL, combo vs. MSA-2, and combo vs. YM101. The CXCL signaling pathway is strengthened in the combo group. B, C Chord diagrams and circular plots illustrating CXCL signaling networks among various cell types in CTL-, MSA-2-, YM101-, and combo-treated tumors. Thicker chords and circles indicate stronger signaling contributions. D Heatmaps showing the communication probability of CXCL signals originating from macrophages and cDCs under each treatment. E Bubble plots identifying potential ligand-receptor pairs contributing to the enhanced CXCL signaling in Combo-treated tumors. Dot color represents communication probabilities, and dot size reflects statistical significance (dots are absent when no communication is inferred). F, G Chord diagrams and circular plots specifically highlighting the CXCL16–CXCR6 axis. H Network analysis mapping the source and target cells involved in CXCL16–CXCR6 signaling. I Venn diagram displaying the number of significantly upregulated genes (UpDEGs) in macrophages from Combo-treated tumors compared to CTL, MSA-2, and YM101 treatments. J Heatmap showing representative immune-related genes with increased expression in macrophages under Combo therapy. K Box plots showing Cxcl16 expression across indicated macrophage subsets in EMT-6 tumors from scRNA-seq data under CTL, MSA-2, YM101, or combination treatment. Data are shown for all macrophages from three pooled samples per group (n = 3). Single cells are shown for visualization only and are not considered independent biological replicates. Box plots show the median (center line), 25th–75th percentiles (box), and whiskers extending to the most extreme values within 1.5 × IQR; outliers are shown as individual points.
3. 优化细胞与组织样本制备(原文Figure 4)
A Flow cytometry (FC) analysis of the relative abundance and fold changes of tumor-infiltrating CD8⁺ T cell subsets across different treatment conditions. Tumors were obtained from an independent cohort in which treatment was initiated when tumors reached 200–250 mm³, and tumors were collected 24 h after completion of the dosing schedule for subsequent flow cytometry analyses (n = 4 per group). B–E Percentage plots showing increased expression of Granzyme-B, Perforin, CD69, and Ki67 in CXCR6⁺ T cells compared to CXCR6− T cells (n = 32 paired samples). F Gating strategy for isolating CXCR6⁺CD8⁺ T cells from tumor-infiltrating lymphocytes for downstream proteomic analyses. G Heatmap of differentially expressed proteins comparing CXCR6⁺ and CXCR6−CD8⁺ T cells (n = 2 per group). H Enrichment analysis of differentially expressed proteins in CXCR6⁺ versus CXCR6−CD8⁺ T cells. I Percentage plots demonstrating higher PD-1 expression in CXCR6⁺CD8⁺ T cells relative to CXCR6−CD8⁺ T cells (n = 32 paired samples). J Co-culture experiment using CXCR6⁺ or CXCR6−CD8⁺ T cells (from OT-1 mice) with EG7-OVA cells, showing enhanced tumor cell death induced by CXCR6⁺CD8⁺ T cells compared to CXCR6− T cells. Anti-PD-L1 treatment further increases cytotoxic activity (n = 3 biological replicates; results are representative of three independent experiments). K Flow cytometry analysis of myeloid cell populations in the EMT-6 model, showing the scaled number of CXCL16+ macrophages (CXCL16+ Mϕ) and dendritic cells (CXCL16+ DC) following treatment with the specified therapies (n = 4 per group). Statistical comparisons were made between the M + Y group and all other treatment groups unless otherwise specified. B–E, I Were analyzed using two-tailed paired t-tests. A, J, K Were analyzed using one-way ANOVA followed by Holm–Šídák’s multiple comparisons test. Statistical significance is indicated as *P < 0.05; **P < 0.01; ***P < 0.001; ****P < 0.0001. Source data and exact P values are provided in the Source data file.
4. 科学结论
DNase I 介导的 DNA 水解是分子实验质控、RNA 纯化、染色质分析的必需步骤;高活性、低污染的 DNase I 试剂是获得可靠数据的核心前提。
三、Absin abs47047435:文献级核心试剂,硬核支撑高分研究
| 产品信息 | 产品名称:脱氧核糖核酸酶 Ⅰ(牛胰) 货号:abs47047435 纯度:高活性,无 RNase 残留,无蛋白酶污染 |
在本文中的关键作用(原文多图核心试剂)
核心优势(高分文献首选理由)
四、Absin 助力生命科学研究:一站式工具酶解决方案
爱必信(Absin)聚焦分子生物学核心需求,提供覆盖工具酶、核酸检测、蛋白研究的全链条试剂:
结语
本项权威研究再次印证:高品质试剂是高分文章的基础保障。Absin abs47047435 凭借高活性、高纯度、低污染的优势,成为核酸代谢、分子互作、样本制备等关键实验的 “标配试剂”。未来,Absin 将持续以文献级品质试剂,赋能全球科研工作者,助力更多高水平研究成果产出!
