当前位置 > 首页 > 技术文章 > 超临界二氧化碳从菠菜中选择性绿色提取单半乳糖基二酰基甘油
浏览次数:38 发布日期:2026-8-17  来源:图拉扬科技
摘要
本研究探讨了使用超临界二氧化碳(CO2)从冻干菠菜(Spinacia oleracea)粉末中纯化高纯度单半乳糖基二酰基甘油(MGDG)的方法。在提取过程中,首先评估了操作条件(包括压力、温度和使用乙醇作为共溶剂)对提取率和脂质选择性的影响。增加压力(200-400巴)和乙醇共溶剂浓度(3.9-6.5%v/v)可提高MGDG提取效率。在优化的提取条件下(400巴、45°C、6.5%乙醇和40克/分钟二氧化碳),在提取期间(15-45分钟),从30克菠菜粉中获得476毫克MGDG,主要与色素共提取。使用活性炭对提取的溶液进行脱色,得到高纯度的MGDG最终提取物,总收率约为84%,相当于402mg MGDG。有趣的是,与菠菜总脂质相比,这些MGDG提取物也富含ω-3脂肪酸,超过87%的总脂肪酸对应于ω-3脂肪酸酯C18:3 n-3(>71%)和C16:3 n-3,(>16%)。
Keywords: spinach, Omega-3, Lipids, glycolipids, monogalactosyldiacylglycerols (MGDG), supercritical carbon dioxide extraction
关键词:菠菜、Omega-3、脂质、糖脂、单半乳糖基二酰基甘油(MGDG)、超临界二氧化碳萃取
2.3.2. Lipid extraction by supercritical carbon dioxide (CO2) at pilot scale
Extraction was carried out on a pilot installation (SFE PROCESS, France). The Process Flow Diagram (PFD) of the installation is shown in Figure 1. The extraction experiments were carried out using a supercritical CO2 extraction system (Extractor) with a capacity of 500 mL, capable of operating at pressures up to 1000 bar and temperatures up to 150 °C. The pressure within the extractor was controlled by a pressure regulator (relief valve P), ensuring stable pressure throughout the process. One separator of 100 mL size was connected at the outlet of the extractor (separation conditions P = 47 bar; T = 45 °C). A heating system was placed around each of the extractor and the separator to ensure precise temperature control throughout the process. For each extraction, 30 g of freeze-dried spinach biomass was loaded in the extractor. The installation was powered by CO2, which was stored in a CO2 cylinder at a pressure of 57 bar. Initially, the CO2 was maintained in the liquid state and pumped with a flow rate of 40 g/min for all the experiments carried out during this study.
2.3.2.超临界二氧化碳(CO2)中试规模脂质提取
提取是在一个试点装置(法国SFE PROCESS)上进行的。装置的工艺流程图(PFD)如图1所示。提取实验使用容量为500 mL的超临界CO2提取系统(提取器)进行,该系统能够在高达1000 bar的压力和高达150°C的温度下运行。提取器内的压力由压力调节器(安全阀P)控制,确保整个过程中的压力稳定。在提取器的出口处连接一个100 mL大小的分离器(分离条件P=47 bar;T=45°C)。在每个提取器和分离器周围都放置了加热系统,以确保整个过程中的精确温度控制。对于每次提取,将30g冷冻干燥的菠菜生物质装入提取器中。该装置由二氧化碳提供动力,二氧化碳以57巴的压力储存在二氧化碳气瓶中。最初,在本研究期间进行的所有实验中,CO2保持液态,并以40g/min的流速泵送.
发布者:图拉扬科技有限公司
联系电话:400-028-9008
E-mail:swg@tlyon.com
标签: 超临界萃取
