2,4-表油菜素内酯溶液(EBR)
浏览次数:1476 发布日期:2018-12-4
2,4-表油菜素内酯溶液 1mg/ml
● 产品包装:
| 产品编号 |
产品名称 |
产品包装 |
说明书 |
| RT1020S |
2,4-表油菜素内酯溶液(1mg/ml) |
5×1ml |
1份 |
22R,23R,24R-2α,3α,22,23-Tetrahydroxy-B-homo-7-oxa-5α-ergostan-6-one
C
28H
48O
6 MW: 480.68 CAS:78821-43-9
● Storage:-20℃
● Specifications:
Soluble…………1 mg/ml (2mM) in Ethanol
Appearance…….colorless clear solution
● Introduction:
Some years ago, organic extracts of
Brassica napus pollen were found to promote stem elongation and cell division in plants. The active components were identified as steroids and have therefore been named brassinosteroids. It is now recognized more and more that brassinosteroids are genuine plant hormones. In the nM to μM range, 2,4-epibrassinolide has been found to promote cell division of protoplasts and to cause hypocotyls elongation, but also to inhibit root extension. Evidence is mounting that it plays a role in vascular differentiation. Much research has been done on the ameliorative effect of brassinosteroids during stress.
