当前位置 > 首页 > 技术文章 > 利用叶片测量仪比较不同作物的叶绿素和多酚指标
浏览次数:1773 发布日期:2022-4-27  来源:本站 仅供参考,谢绝转载,否则责任自负
Dualex是一款源自于法国国家科学院 (CNRS)及巴黎第十一大学技术,由奥地利PESSL公司生产(原法国Force-A公司)开发的新型多功能叶片测量仪。它可同时准确测量叶片的叶绿素含量、叶片表层的类黄酮和花青素含量,适用于植物生理学和农学(如水稻叶绿素浓度,玉米氮素状况,葡萄藤等)相关研究。
其测量对象可以是单子叶植物,双子叶植物或多年生植物。这款设备简单易用,可进行实时和非破坏性测量。由于不需要校准标定和事先的样品制备,测量工作可在实验室或现场完成。此外,该设备在各种温度的和环境光照条件下均可正常使用。系统采用专利设计,光学传感器可进行简单、快速、无损测量叶片中的叶绿素、多酚以及花青素。
Dualex便携式智能气象-叶绿素-花青素-黄酮醇测量仪
摘要
很难为每个地方找到合适的农业能源物种且这些物种具有潜在的生物量。因此,有必要研究新物种。通过对这些物种的种植研究,我们可以了解它们作为能源作物的行为。白榆是一种很好的能源作物。然而,最好使用更多的本土物种和其他特征物种,因此我们研究了五个不同的榆树无性系。其中,比较了用DUALEX®单位测量的叶绿素和多酚指数。被比较的克隆:“Olma de Ribatajada”(小榆的克隆体),“Olma de Pareja”(小榆的克隆体),金叶榆的克隆。此外,还研究了白榆的两个不同无性系的叶绿素指数、黄酮醇指数、花青素指数和NBI®氮状态(叶绿素/黄酮醇比率)。这篇文章研究在“El Encín”庄园进行。种植不同无性系的插条,七个月后进行测量。随着时间的推移,有必要继续研究无性系和其他形态农艺性状,以确定更适合生物质能源作物的榆树种类。
Chlorophyll index.
Flavonoids index.
Nitrogen Balance index.
 Anthocyanins index.
COMPARISON OF CHLOROPHYLL AND POLYPHENOLS INDEXES IN DIFFERENT SPECIES OF ELM FOR USE AS ENERGY CROPS
Abstract
Finding suitable agroenergetic species for each place and that these species are potential for biomass is difficult. For this reason, it is necessary to study new species. Studying these species from planting, we can get an idea of their behavior as an energy crop. Due to its characteristics, Ulmus pumila L. is a good species to use as energy crop. However, it is good to use more autochthonous species and with other characteristics, that is why we have studied five different clones of Elms. In them, we have compared the indices of chlorophyll and polyphenols, measured with the DUALEX® unit. The clones that were compared: "Olma de Ribatajada" (clone of Ulmus minor Mill.),"Olma de Pareja" (clone of Ulmus minor Mill.), a clone of Ulmus laevis Pall. moreover, two different clones of Ulmus pumila L. The chlorophyll index, flavonol index, anthocyanin index and the NBI® nitrogen status (chlorophylls/flavoles ratio), there were studied. This essay was located at the estate "El Encín" in Alcalá de Henares, belonging to IMIDRA. The cuttings of the different clones were planted and after seven months, the measurements were taken. It is necessary to continue studying the clones and other morphoagronomic characters over time in order to determine the species of elm that are more suitable for the energy crop of biomass.
相关阅读
Dualex 便携式智能气象-叶绿素-花青素-黄酮醇测量仪
PESSL便携式便携式植物多酚-叶绿素仪原理
Dualex植物多酚-叶绿素仪:腐殖酸通过铁依赖和非铁依赖的协同机制缓解禾本科植物的铁失绿症
Dualex植物多酚-叶绿素仪:硝化抑制剂和/或间作效应下玉米(和小麦灌溉种植系统中的硝酸盐淋失
Dualex植物多酚-叶绿素仪:与保持绿色表达相关的叶片和冠层性状与对水分胁迫具有不同耐性的小麦基因型的产量构成密切相关
Dualex植物多酚-叶绿素仪:基于地面和智能传感器的冬小麦营养营养仪
Dualex植物多酚-叶绿素仪:增加角质层蜡沉积不会改变残余叶片蒸腾作用
Dualex植物多酚-叶绿素仪--氮平衡指数:不同生物刺激剂对水培生菜的效果比较
Dualex植物多酚-叶绿素仪:固体消化物和葡萄园冬季修剪堆肥替代苗圃中微繁殖高丛蓝莓生长基质中的泥炭研究
Dualex植物多酚-叶绿素仪:不同灌溉制度下根际细菌和藻类对金盏草生理生化指标的影响
Dualex植物多酚-叶绿素仪:Sentinel-2A与近端传感器数据协同提取水稻不同生育期生化参数
Dualex植物多酚-叶绿素仪:三种便携式光学传感器在冬小麦氮素状况无损诊断中的应用
Dualex植物多酚-叶绿素仪:基于微碳技术(MCT®)的肥料对土壤和辣椒生长室和田间培养的生物刺激效应
Dualex植物多酚-叶绿素仪:根际细菌在减轻大豆干旱胁迫中的作用
Dualex植物多酚-叶绿素仪:不同辐射组分下水分亏缺对苹果幼苗生长的影响
Dualex植物多酚-叶绿素仪:不同的非生物光谱途径揭示了不同物种的病原体应激信号
Dualex植物多酚-叶绿素仪:用于在田间估算葡萄叶片氮状况的反射指数和手持设备的性能
Dualex植物多酚-叶绿素仪:短期采前补充UV-B可提高罗勒叶片贮藏期间的多酚含量和抗氧化能力
Dualex植物多酚-叶绿素仪:基于图像处理技术的5种红树林叶片形态特征及叶绿素相对含量的估测
Dualex植物多酚-叶绿素仪:利用叶片荧光传感器估算玉米各生育期植株氮浓度
发布者:北京博普特科技有限公司
联系电话:010-82794912
E-mail:haohuakun@163.com
