当前位置 > 首页 > 技术文章 > 高通量叶绿素荧光成像平台在微生物与表型组学领域应用
浏览次数:792 发布日期:2021-2-26  来源:本站 仅供参考,谢绝转载,否则责任自负
来自根特大学的科学家利用表型设备制造商SMO公司构建的Pathoviewer高通量表型成像平台发表了题为At the scene of the crime: New insights into the role of weakly pathogenic members of the fusarium head blight disease complex的文章,该Pathoviewer系统整合了叶绿素荧光成像系统模块。该系统属于WIWAM XY的定制系列的一种。
WIWAM XY植物表型成像系统(定制版)
含GFP蛋白的植物RGB图像; Pathoviewer多光谱相机图像.
含GFP的小麦RGB 图像; Pathoviewer多光谱相机图像.
WIWAM植物表型成像分析系统由Ghent大学的VIB研究所、世界先进的自动化工程公司SMO联合欧洲先进科学家合作研制生产的新型植物表型组学研究平台,可以全自动、高通量、高容量测量分析拟南芥、水稻、玉米、大豆等各种植物的三维表型形状及生理状态及其与环境条件关系。
WIWAM植物表型成像分析系统可集成各种成像模块,如自动化控制系统、荧光成像测量分析(包括叶绿素、红荧光)、植物红外热成像分析、植物近红外成像分析、植物多光谱分析、植物高光谱分析、自动条码识别管理、RGB真彩3D成像、激光3D多光谱成像、计算机断层扫描技术、自动称重与浇灌系统等多项先进技术,实现生理生态与形态结构成像分析,用于高通量植物表型成像分析测量、植物胁迫响应成像分析测量、植物生长分析测量、生态毒理学研究、性状识别及植物生理生态分析研究等。
Jiang Tan ,Maarten Ameye ,Sofie Landschoot ,Noémie De Zutter ,Sarah De Saeger Marthe De Boevre,Mohamed F. Abdallah ,Theo Van der Lee ,Cees Waalwijk ,Kris Audenaert
Abstract
Plant diseases are often caused by a consortium of pathogens competing with one another to gain a foothold in the infection niche. Nevertheless, studies are often limited to a single pathogen on its host. In Europe, fusarium head blight (FHB) of wheat is caused by multiple Fusarium species, including Fusarium graminearum and F. poae. Here, we combined a time series of (co)inoculations, monitored by multispectral imaging, transcriptional, and mycotoxin analyses, to study the temporal interaction between both species and wheat. Our results showed coinoculation of F. graminearum and F. poae inhibited symptom development but did not alter mycotoxin accumulation compared to a single inoculation with F. graminearum. In contrast, preinoculation of F. poae reduced both FHB symptoms and mycotoxin levels compared to a single F. graminearum infection. Interestingly, F. poae exhibited increased growth in dual infections, demonstrating that this weak pathogen takes advantage of its co‐occurrence with F. graminearum. Quantitative reverse transcription PCR revealed that F. poae induces LOX and ICS gene expression in wheat. We hypothesize that the early induction of salicylic and jasmonic acid‐related defences by F. poae hampers a subsequent F. graminearum infection. This study is the first to report on the defence mechanisms of the plant involved in a tripartite interaction between two species of a disease complex and their host.
发布者:北京博普特科技有限公司
联系电话:010-82794912
E-mail:haohuakun@163.com
