当前位置 > 首页 > 技术文章 > 多光谱成像和X光图像在鉴别麻风树种子品质与种子表型研究的应用
浏览次数:1211 发布日期:2020-5-18  来源:本站 仅供参考,谢绝转载,否则责任自负
最近,来自Aarhus大学以及丹麦理工大学的科学家利用多光谱成像设备以及X光设备发表了题为Multispectral and X-ray  Images for Characterization of Jatropha Curcas L. Seed Quality的文章,结论显示MSI多光谱成像技术以及X光图像在麻风树的种子生理性能研究上有强相关性。 此类技术可作为未来替代方法用于快速、有效、可持续、无损鉴别麻风树种子品质,克服传统种子品质分析内在主观性。
研究中使用了Videometer开发的多光谱成像系统,该系统是种子品质以及种子表型组学研究的利器,目前为止,利用该设备已经发表了多达250多篇文章。
seed viability, non-destructive analysis, machine vision, artificial intelligence
Jean M Carstensen
Danmarks Tekniske Universitet
Birte Boelt
Aarhus Universitet
Background: Jatropha curcas  is an oilseed plant with great potential for biodiesel production. In agricultural industry, the seed quality is still estimated by manual inspection, using  destructive, time-consuming and subjective tests
that depend on the seed analyst experience. Recent advances in machine vision  combined with artificial intelligence algorithms can provide spatial and spectral information for characterization
of biological images, reducing subjectivity and optimizing the analysis process.
Results: We present a new method for automatic characterization of jatropha seed quality, based
 on multispectral imaging (MSI) combined with X-ray  imaging. We propose an approach along  with X-ray  images in order  to investigate internal problems such as damages in the embryonic axis and endosperm, considering the fact
 that seed surface profiles can be negatively affected, but without reaching important internal
regions of the seeds.  Our studies included the application of a normalized canonical discriminant analyses (nCDA)
 algorithm as a supervised transformation building method to classify spatial and spectral patters according to
the classes  of seed quality. Spectral reflectance signatures in a range  of 780 to 970 nm and the X-ray  images can efficiently predict quality traits such as normal seedlings, abnormal seedlings and dead  seeds.
Conclusions: MSI and X-ray  images have  a strong relationship with physiological performance of Jatropha curcas  L. These techniques can be alternative methods for rapid, efficient, sustainable and non-destructive characterization of jatropha seed quality in the future, overcoming the intrinsic subjectivity of the conventional seed quality
发布者:北京博普特科技有限公司
联系电话:010-82794912
E-mail:haohuakun@163.com
