BD流式细胞仪常用试剂与耗材
优宁维流式网
System Reagents
系统试剂
| DESCRIPTION | APPS | SIZE | CAT NO. |
| BD FACSCount Reagent Kit (50 pair of CD3/CD4 and CD3/CD8 reagents,Fixative solution(two 5-mL vialsof 5% formaldehyde),Tube caps) |
FCM | 50 tests | 340167 |
| HLA-B27 kit (Anti-HLA-B27 FITC/CD3 PE,HLA-B27 calibration beads,BD FACS lysing solution) |
FCM | 50 tests | 340183 |
BD Single-Color Reagents / Trucount Tubes
BD单色试剂/绝对计数管
| DESCRIPTION | CLONE | FORMAT | APPS | SIZE | CAT NO. |
| CD4 | SK3 | FITC | FCM | 100 tests | 340133 |
| CD19 | SJ25C1 | APC | FCM | 100 tests | 340437 |
| CD45(Leukocyte Common Antigen) | 2D1 | FITC | FCM | 100 tests | 347463 |
| CD45(Leukocyte Common Antigen) | 2D1 | PerCP | FCM | 100 tests | 347464 |
| CD34 | 8G12 | PE | FCM | 100 tests | 348057 |
| BD Trucount Tubes | FCM | 50 tests | 340334 |
BD Simultest Two-Color Reagents
BD Simultest双色试剂
| CD3/CD16+CD56 | SK7,B73.1,MY31 | FITC,PE,PE | FCM | 50 tests | 340042 |
| IMK-Lymphocyte Kit (a BD FACS lysing solution and six BD Simultest reagents:BD Leucogate(CD45/CD14),Isotype Control (g1/g2a),CD3/CD19,CD3/CD4,CD3/CD8,CD3/CD16+CD56) |
FITC,PE | FCM | 50 tests | 340182 |
BD Tirtest Three-Color Reagents
BD Tirtest三色试剂
| CD4/CD8/CD3 | SK3,SK1,SK7 | FITC,PE,PerCP | FCM | 50 tests | 340298 |
| CD4/CD8/CD3 with BD Tirtest Tubes | SK3,SK1,SK7 | FITC,PE,PerCP | FCM | 50 tests | 340401 |
| CD3/CD4/CD45 | SK7,SK1,2D1 | FITC,PE,PerCP | FCM | 50 tests | 340383 |
| CD3/CD4/CD45 with BD Tirtest Tubes | SK7,SK1,2D1 | FITC,PE,PerCP | FCM | 50 tests | 340402 |
BD Multitest Four-Color Reagents
BD Multitest四色试剂
| CD3/CD8/CD45/CD4 | SK7,SK1,2D1,SK3 | FITC,PE,PerCP,APC | FCM | 50 tests | 340499 |
| CD3/CD8/CD45/CD4 with BD Trucount Tubes | SK7,SK1,2D1,SK3 | FITC,PE,PerCP,APC | FCM | 50 tests | 340491 |
| IMK Kit (BD Mulititest CD3/CD8/CD454/CD4 Reagent, PerCP,APC BD Mulititest CD3/CD16/+CD56/CD45/CD19 Reagent,BD FACS Iysing solution) |
FITC,PE,PerCP,APC | FCM | 50 tests | 340503 | |
| IMK Kit BD Trucount Tubes (BD Mulititest CD3/CD8/CD454/CD4 Reagent,BD Mulititest CD3/CD16/+CD56/CD45/CD19 Reagent,BD FACS Iysing solution) |
FITC,PE,PerCP,APC | FCM | 50 tests | 340504 |
BD Multitest Six-Color Reagents
BD Multitest六色试剂
| BD Mulititest 6 Color TBNK with BD Trucount Tubes (CD3 FITC/CD16 PE+CD56 PE/CD45 PerCP-Cy5.5/CD4 PE-Cy7/CD19 APC/CD8 APC-Cy7/ and BD TrucountTM Tubes) |
SK7,B73.1,NCAM 16.2,2D1(HLe-1),SK3,SJ25C1,SK1 | FITC,PE, PerCP-Cy5.5/,PE-Cy7,APC, APC-Cy7 | FCM | 50 tests | 337166 |
DNA Reagents
DNA 检测试剂
| CycleTEST Plus DNA Reagent Kit (Solution A: trypsin in spermine tetrahydrochoride detergent buffer; Solution B:RNase A and typsin inhibitor in spermine buffer; Solution C:Propidium Iodide(PI) in spermine buffer;Buffer Solution:dimethylsulfoxide(DMSO) in sucrose-sodium critrate) |
FCM | 40 tests | 340242 |
Isotype Controls
同型对照
| Mouse IgG1 Control | X40 | FITC | Ctrl | 100ug | 349041 |
| PE | Ctrl | 100ug | 349043 | ||
| Mouse I IgG2a Control | X39 | FITC | Ctrl | 100ug | 349051 |
| PE | Ctrl | 100ug | 349053 |
Sample Preparation Reagents and Consumables
样本制备试剂及耗品
| BD FACS Lysing Solution 10X | FCM | 30ml | 347691 |
| BD FACS Lysing Solution 10X | FCM | 100ml | 349202 |
Instrument Setup and and Maintenance
仪器校准与维护
| DESCRIPTION | FORMAT | APPS | SIZE | CAT NO. |
| BD FACSFlow Sheath Fluid | FCM | 20L | 342003 | |
| BD FACS sheath solution with surfactant | FCM | 20L | 336524 | |
| BD FACS Clean Solution | FCM | 5L | 340345 | |
| BD FACS Rinse Solution | Unlabeled,FITC,PE,PerCP | FCM | 5L | 340346 |
| BD Calibrite 3 Beads | APC | FCM | 25 tests | 340486 |
| BD Calibrite APC Beads | FCM | 25 tests | 340487 | |
| BD FACS 7-Color Setup Beads | FCM | 25 tests | 335775 | |
| BD Cytometer Setup&Tracking Beads Kit | FCM | 50 tests | 641319 | |
| FCM | 150 tests | 642412 | ||
| BD FACS Shutdown Solution | FCM | 5L | 334224 |
Instrument Components/Consumables
仪器组件及耗品
| FACSCalibur Bal seal for SIP | FCM | 1个 | 343509 |
| FACSCalibur Sheath filter | FCM | 1个 | 343542 |
| FACSCalibur Sheath filter assembly | FCM | 1个 | 02-61366-00 |
| FACSCantoll Sheath filter | FCM | 1个 | 336945 |
| FACSCantoll Sheath filter Assemble | FCM | 1个 | 33566307 |
BD Falcon Tubes
BD Falcon流式进样管(聚苯乙烯)
| Falcon流式进样管(聚苯乙烯),12X75ml,5ml | 无盖,无菌 | FCM | 1000支/包,1000/箱 | 352008 |
| Falcon流式进样管(聚苯乙烯),12X75ml,5ml | 无盖,无菌 | FCM | 125支/包,1000/箱 | 352052 |
优宁维流式网(www.my-fcm.com.cn)
联系方式:4006-365-264(4006-365天-爱流式)
Email:fcm@univ-bio.com
流式试剂
公众号:流式专家
