当前位置 > 首页 > 技术文章 > 利用高通量微流体技术研究单细胞生物系统运作相关文章
浏览次数:3233 发布日期:2010-7-26  来源:本站 仅供参考,谢绝转载,否则责任自负
2010年7月Nature发表利用高通量微流体技术研究单细胞生物系统运作相关文章
简介
在动态的环境里面,细胞们通过各遗传途径的相互作用交流运转着。哺乳动物免疫反应就是各类不同的细胞协同合作的一个惊人例子。细胞与细胞之间的交流主要是通过信号分子形成时间与空间浓度梯度来介导的,这就要求细胞对一个大范围内的信号强度产生响应。这篇文章采用高通量的微流体细胞培养(high-throughput microfluidic cell culture)和荧光显微镜,定量基因表达分析和建立数学模型等研究手段来评估到底单个哺乳动物细胞如何对不同浓度的信号分子TNF-α产生相应的响应。 并高度肯定了以单细胞级别进行高通量基因定量对研究生物系统如何运作的价值。
Letter
Nature 466, 267-271 (8 July 2010) | doi:10.1038/nature09145; Received 29 December 2009; Accepted 28 April 2010; Published online 27 June 2010
Single-cell NF-
κB dynamics reveal digital activation and analogue information processing Savaş Tay1,2,4, Jacob J. Hughey1,4, Timothy K. Lee1, Tomasz Lipniacki3, Stephen R. Quake1,2 & Markus W. Covert1
1.  Department of Bioengineering, Stanford University, Stanford, California 94305, USA
2.  Howard Hughes Medical Institute, Stanford, California 94305, USA
3.  Institute of Fundamental Technological Research, Warsaw 02-106, Poland
4.  These authors contributed equally to this work.
Abstract
Cells operate in dynamic environments using extraordinary communication capabilities that emerge from the interactions of genetic circuitry. The mammalian immune response is a striking example of the coordination of different cell types1. Cell-to-cell communication is primarily mediated by signalling molecules that form spatiotemporal concentration gradients, requiring cells to respond to a wide range of signal intensities2. Here we use high-throughput microfluidic cell culture3 and fluorescence microscopy, quantitative gene expression analysis and mathematicalmodelling to investigate how single mammalian cells respond to different concentrations of the signaling molecule tumour-necrosis factor (TNF)-α, and relay information to the gene expression programs by means of the transcription factor nuclear factor (NF)-κB. We measured NF-κB activity in thousands of live cells under TNF-α doses covering four orders of magnitude. We find, in contrast to population-level studies with bulk assays2, that the activation is heterogeneous and is a digital process at the single-cell level with fewer cells responding at lower doses. Cells also encode a subtle set of analogue parameters to modulate the outcome; these parameters include NF-κB peak intensity, response time and number of oscillations. We developed a stochastic mathematical model that reproduces both the digital and analogue dynamics as well as most gene expression profiles at all measured conditions, constituting a broadly applicable model for TNF-α-induced NF-κB signalling in various types of cells. These results highlight the value of high-throughput quantitative measurements with single-cell resolution in understanding how biological systems operate.
发布者:广州进科驰安科技有限公司
联系电话:17620093784
网友评论 已有[1]人评论
lianglihua_26 (168.160.250.60)
昵称:AA 内容:第二届亚太生物与化学微流体会议5月份在南京工业大学举办。会议联系:中国化工信息中心梁立华010--64418019,13683509714
2011-3-7 14:33:00
