当前位置 > 首页 > 行业资讯 > 促销 > fdneurotech产品 购买五支以上有更多惊喜等着您
浏览次数:1173 发布日期:2012-10-26  来源:本站 本站原创,转载请注明出处
北京泰泽瑞达科技有限公司
免费订购热线:400-800-8151
地址:珠江峰景24号楼4层
Staining Kits & Accessories
  • FD Apop™ Kit (PK101)
  • FD NeuroApop™ Kit (PK201)
  • FD NeuroSilver™ Kit II (large) (PK301)
  • FD NeuroSilver™ Kit II (small) (PK301A)
  • FD Rapid GolgiStain™ Kit (large) (PK401)
  • FD Rapid GolgiStain™ Kit, Solution C Only (PK401-C)
  • FD Rapid GolgiStain™ Kit (small) (PK401A)
  • FD Rapid MultiStain™ Kit (PK501)
  • FD Rapid TimmStain™ Kit (PK701)
  • Control Sections for FD NeuroSilver™ Kit II (PCS101)
  • Control Sections for FD NeuroApop™ Kit, Paraffin sections (PCS102-01)
  • Control Sections for FD NeuroApop™ Kit, Frozen sections (PCS102-02)
Staining Solutions
  • FD Thionin Solution™ Regular Strength (PS101-01)
  • FD Thionin Solution™ Double Strength (PS101-02)
  • FD Cresyl Violet Solution™ Regular Strength (PS102-01)
  • FD Cresyl Violet Solution™ Double Strength (PS102-02)
  • FD Eosin Y Solution™ Regular Strength (PS103-01)
  • FD Eosin Y Solution™ Double Strength (PS103-02)
  • FD Hematoxylin Solution™ Regular Strength (PS104-01)
  • FD Hematoxylin Solution™ Double Strength (PS104-02)
  • FD Methyl Green Solution™ Regular Strength (PS105-01)
  • FD Methyl Green Solution™ Double Strength (PS105-02)
  • FD Neutral Red Solution™ Regular Strength (PS106-01)
  • FD Neutral Red Solution™ Double Strength (PS106-02)
  • FD Azure II Solution™ Regular Strength (PS107-01)
  • FD Azure II Solution™ Double Strength (PS107-02)
  • FD Congo Red Solution™ (PS108)
  • FD Luxol Fast Blue Solution™ (PS109)
Tissue Preparation Solutions
  • FD Section Storage Solution™ (PC101)
  • FD Tissue Cryoprotection Solution™ (PC102)
  • FD Tissue Storage Solution™ (PC103)
  • Phosphate-Buffered 4% Paraformaldehyde (PF101)
  • EmbryoFix™ (PF102)
  • Phosphate-Buffered 4% Paraformaldehyde with Picric Acid (PF103)
Laboratory Supplies
  • Gelatin-Coated Microscope Slides (PO101)
  • Proteinase-Resistant Microscope Slides (PO102)
  • Superfrost® Plus Microscope Slides (25 mm x 75 mm) (PO103)
  • Gold Seal® Rite-On® Frosted Slides (25 mm x 75 mm) (PO104)
  • Box for 1" x 3" Microscope Slides (holds 100 slides) (PO201)
  • 25-Place Microscope Slide Box (PO202)
  • Box for 2" x 3" Microscope Slides (holds 100 slides) (PO203)
  • Section incubation plate with 6 inserts (PO301)
  • Section incubation plate with 12 inserts (PO302)
  • Section incubation tray, black or white (PO303)
  • Section incubation insert carrier (for 6 wells) (PO304)
  • Section incubation insert carrier (for 12 wells) (PO305)
  • Fine natural hair brush for mounting sections (PO501)
Embryonic Sections
  • Mouse EmbryoSections, fixed/paraffin, 9 day (PE102-09)
  • Mouse EmbryoSections, fixed/paraffin, 10 day (PE102-10)
  • Mouse EmbryoSections, fixed/paraffin, 11 day (PE102-11)
  • Mouse EmbryoSections, fixed/paraffin, 12 day (PE102-12)
  • Mouse EmbryoSections, fixed/paraffin, 13 day (PE102-13)
  • Mouse EmbryoSections, fixed/paraffin, 14 day (PE102-14)
  • Mouse EmbryoSections, fixed/paraffin, 15 day (PE102-15)
  • Mouse EmbryoSections, fixed/paraffin, 16 day (PE102-16)
  • Rat EmbryoSections, fixed tissue embedded in paraffin, 10 day (PE202-10)
  • Rat EmbryoSections, fixed tissue embedded in paraffin, 11 day (PE202-11)
  • Rat EmbryoSections, fixed tissue embedded in paraffin, 12 day (PE202-12)
  • Rat EmbryoSections, fixed tissue embedded in paraffin, 13 day (PE202-13)
  • Rat EmbryoSections, fixed tissue embedded in paraffin, 14 day (PE202-14)
  • Rat EmbryoSections, fixed tissue embedded in paraffin, 15 day (PE202-15)
  • Rat EmbryoSections, fixed tissue embedded in paraffin, 16 day (PE202-16)
  • Rat EmbryoSections, fixed tissue embedded in paraffin, 17 day (PE202-17)
  • Rat EmbryoSections, fixed tissue embedded in paraffin, 18 day (PE202-18)
